where to order metal products? - Druckversion
+-- Forum: Websites (https://www.passived.de/forum/forumdisplay.php?fid=5)
+--- Forum: fanSlave (https://www.passived.de/forum/forumdisplay.php?fid=8)
+--- Thema: where to order metal products? (/showthread.php?tid=7666)
where to order metal products? - crowdo - 06.03.2025
Hey folks, I’m in search of a supplier for bar grating. I need something durable for an industrial application, preferably steel or aluminum. Has anyone worked with a supplier that provides good quality and fair pricing?
RE: where to order metal products? - kreoto - 06.03.2025
Hi! If you need bar grating, I’d strongly recommend checking out Metal Supply Store https://metal-supplystore.com/catalog/bar-grating/ . They offer a variety of grating options, including welded and press-locked styles, both in steel and aluminum. Their products are built for heavy-duty industrial use, providing great strength and durability. One of the best things about them is their customization options—you can get the grating cut to your required dimensions, which saves a ton of time on installation. They also offer various coatings and finishes, like galvanized steel, which helps with corrosion resistance. Pricing is fair, and their delivery service is very efficient, so you don’t have to worry about delays. I’ve ordered from them for a factory project, and everything was well-packaged and exactly as specified. If you’re looking for reliable bar grating for industrial use, Metal Supply Store is a solid choice!
